CONCLUSION... (Part 1, GP life exp: jury still out...)
Bingo aggie... that's what we did in a nutshell... I just threw in a switch as well to be able to choose mod/stock.
Some people might not want to do the mod just yet though... Here's my take on the situation:
I wanted to give this circuit a good amount of time in use to see it's behavior. Different ambient temps at startup/trip lengths/length of time between starts... etc. After a few months of using it on and off, and comparing mod vs stock I have concluded this:
This is a mod that works. It works as expected. There have been no surprises as far as the mods performance in it's ability to regulate the GP's...
However, I WILL offer one caveat:
My engine has ongoing air issues... Whether minor or major, I know lots of others struggle with this too. So i figure this is worth mentioning. When the temp switch is active and the GP's don't come on due to the mod... that's great.
But the temp switch also deactivates the high idle on a warm restart. This means a warm engine, with an air issue, when being restarted... will have an even less rich mixture during the restart because of that extra air... I have noticed that in my case, having the GP's come on HELPS this... even if just a little.
Scenario(s) I've noticed: if my temp switch is reading around 120F from the coolant after a while of sitting, the high idle won't get set when I go to restart it, but air was intruding for that sitting period...
1: Restart with the circuit engaged and the GP's off: SMOOOOOOOOOOOOOOOOOOKE...
2: Restart with the circuit off, and the GP's come on: SMOOOKE...
Basically, the GP's coming on are actually good for "airy" fuel systems, it seems... Magic formula: air/fuel/heat. So when the air/fuel are off a bit, the extra heat helps.
So, I guess what I would say to those with air issues: SOLVE ANY AND ALL AIR PROBLEMS FIRST before you do this. Get her air tight. The GP life expectancy change is unknown still. Only further use will really tell if the GP's lives are extended beyond normal life expectancy... and whatever prolonged life you hope to get out of your GP's doing this might be lost due to incorrect operation from air intrusion...
OR ...if you're like me, and just can't resist, at least put that switch in the circuit in too so you have the option of stock operation after the mod...
...and for those with absolutely no air issues... well... SUCK IT!
(that's my jealousy talking)
You obviously are better at this than I am, so you shouldn't be listening to me anyway!
One more update will come after i get every last air issue solved... who knows when the hell that will happen.
All in all though, I think this is a successful mod.
p.s. write-up will happen when I get time. no telling when that may be...
