Hey guys I'm back with more questions. Thanks for humoring me...I hope!
So I bought a old truck with a turbo charged 6.9 IDI and a Gear Vendor. This is on a regular cab truck with a C6 and a BW 1345 transfer case. The back of the transfer case has the Gear Vendors symbol.
I got the engine to go in the old truck but it has sat for so long there is a LOT to do to get the truck running where I trust it.
Just last week I bought a 4X4 extended cab mid 90's 6.9 IDI pickup truck with a T19 four speed manual. I know this truck and the engine was completely rebuild a year ago. I'd like to put my gear vendors into this truck but I'm not sure how to go about it. I'm assuming I can replace the transfer case that is currently in it with the one that has the Gear Vendors attached. This package is longer than my existing transfer case however and puts the tail shaft about 12 inches closer to the steady bearing as far as I can tell. Will this cause my drive shaft angles to be messed up? Can I lower my steady bearing with shims to help?
I took a look through the tech articles and I couldn't find any answers. The search feature also didn't pull up much.
Thanks for any help you guys can provide!
