Flex plate for 7.3/C6
homelessduck
The teeth are all chewed up. Anyone have one in good condition ?
Really most any good trans repair shop will have one. I know BTS (Brians Truck Shop) has one. Remember to seal the threads on all the bolts because they enter the oily side of the crank oil pan. the crank flange is drill all the way thru the flange so you bet the crankcase oil leaks out past the threads making a holly heel mess under there.
homelessduck
Thanks Gary. Turns out mine is the one with a removable ring gear. O'Reilly's has them for $30. So I don't need one anymore. I will be sure to seal the bolts. Thanks.
lewisstevey7
