Starting to search out and borrow an engine stand for my tear down and need to know what do these engines weigh fully dressed fellas, and please gestimators need not answer this ? on account of i need my feet.
These motors weigh between 1100 and 1200 lbs.. Use only a 2 ton engine stand and even then be very careful around it. No harbor freight 1 ton stand will support it. Others have tried.... Others have failed....
i used a 2 ton crane and a 1 ton stand. the stand is a relic, way overbuilt, and even then i was a little worried so i made sure to leave the crane attached with a little tension on the chain in case something happened
after i got the heads and crank out it was better, but the bare block has to weigh about the same as your average iron block/aluminum head setup
i used the BIGGEST harbor frieght stand i could find, i had to notch out the one part so it would open enough to bolt on. i had no trouble with it, if it was sitting for a while i'd prop it up with a 4x4.
