E40D overdrive not working
Sam7.3
Ofallon
I have a 92 7.3 f350. When i first got the truck I mainly drove around town and never paid attention to the OD not working. Last week I was getting ready to move 4hrs away so i decided to see if i could try to fix the OD problem. I checked the wires in the column to see if they have been ruined and the were fine. then i checked all fuses/ relays and everything seems to working fine. While driving on the highway at 65mph the rpms were at 3k which to me seems very high. CAN ANYONE HELP!!!:mad:
DaveBen
Ukiah, Ca
Depends on the rear end gear ratio. My 92 had 4.10 gears and 3,000 rpm at 70 was right on. I am betting you have 4.10's also.
Sam7.3
Ofallon
yeah i have 4:10s, so being at 3,000 is normal and is it okay to run the truck for a long time at those rpm's??
Mherriford
Oregon
Overdrive should not be at 3 rpm at 70 even with 4.10 rear end gears. I have a 4.10 rear c-6 truck, and i get 300 rpm at 70, overdrive should be 500 or so rpm lower I would think k
Sam7.3
Ofallon
yeah i thought it would be lower than 3rpm, i read a couple forums online and people who have the e40d with 4:10 gears say theyre getting around 2400/2500rpm.
BDCarrillo
Abilene TX
Well, 3000 rpm with a 4.10 rear and e4od, assuming 33" tires, should be 101 MPH in OD. 3rd should be 71mph at 3000 RPM.
Couple things to check: E4OD codes, and tach sensor.
Does your tach drop to zero at idle or hop up to ~2000 rpm right off idle? Floaty tach needle?
Does clicking the OD button cause an audible change in RPM?
Your exact tire size and exact speed/RPM at your top gear would help too.
Sam7.3
Ofallon
when going 40 and i let off the throttle the rpms drop from 2k to 1k but at half throttle going up to 45 at 40 there is a jump in rpms (about 200). Clicking the button does nothing to the rpms. at 70 i am at 3200rpm. I have 4:10 gears, 33'' tires (technically 32.8'') but who's counting LOL
BDCarrillo
Abilene TX
Well, the math puts us at 76 mph. You may have slippage in the lockup clutch... but that's a wild guess.
Best guesstimate at this point would be to pull and clean solenoid plug (pass side of tranny, big bundle o wires). Your TECA/TCU should be going bananas and throwing error codes since it's probably trying to command a gear, but it's not happening.
OD light dim or flashing? You can pull codes on the E4OD with a Ford OBDI reader.
How to read tranny codes: http://www.oilburners.net/forums/showthread.php?4135-DTC-s-on-the-E4OD
Tranny wiring and code reference: http://www.oilburners.net/forums/showthread.php?70217-Testing-E4OD-Solenoid-Pack-and-Code-referrence
Last (easy) thing to check: FIPL http://www.oilburners.net/forums/showthread.php?4134-Whats-a-FIPL
Sorry about the shotgun of info... but I'd check codes first and go from there. The E4OD relies on the FIPL, tach, and speedo sensor to figure what's going on. If any of those are acting up, the TECA might know.
Sam7.3
Ofallon
I need all the info i can get, i just test the FIPL, paperclip into the back of the grey and white wire, at "idle" it read .5v at WOT it read 3.8. I defiantly need to adjust it. I will do that tomorrow morning and see how it goes . Thanks everyone for the help thus far.
FORDF250HDXLT
Maine & Oklahoma
no 3-4 shift causes.............
attachment.php
if it's this one,your SOL.time for a reman.
attachment.php
Sam7.3
Ofallon
I have checked all i can check without dropping the pan. I think its a floaty tach needle, how do i fix this?
A new tach sensor or pull it out and clean it, sounds like it may have metal chips on it, there pretty sensitive.The sensor has a magnet in it and uses the Hall effect, any metal stuck to the end of it will/can cause a floaty tach.
The faster the speed you go, the more RPM error occurs.
Sam7.3
Ofallon
where is this located?
This is it on the side of the ip gear housing.
