Drive shaft U joints
jauguston
Retired
Bellingham, WA
Low speed vibrations can often be caused by improper U-joint angle. I installed a GV overdrive and got a low speed (25-30 mph) vibration. Ford doen't have very good U-joint angles to start with says the local driveline service shop and a shorter front shaft aggravates the situation. My front shaft is only 13" long now and I am working with shimming the transmission mount and carrier bearing mount to try and make it better. Its not perfect yet.
Jim
adrianspeeder
USAF C-17 Avionics
Air Force
Dover AFB / Harrisburg PA
Aight, got the 88's front dshaft out and look at that front joint...
Vice wasn't budgin it.
Needed the sledge, a piece of bar stock, and this custom woodblock.
Just sucks on the amount of rust the '88 has. Me thinks the '84 was laughin at me futzin around with the whole deal in the garage.
Anyway, any tips for puttin the new joints in when I get the second one on Tuesday?
Adrianspeeder
metrojd
Pittsburgh,Pa
Vibration
I had a vibration at about 2200 rpm no matter what speed I was going or what gear I was in.
Turned out to be the carrier bearing.
As far as U Joints I havent had luck with Brute Force, The ones I had had no grease fittings.
I use Spicer.
I also have installed a GV and have a low speed vibration now.
It mainly seems its when I lay into it pulling out.
gabbyr100rs
Acworth, GA
A few years ago, I had a low speed vibration under load--pretty much wen away by 50 MPH--that I thought was a misfire--did all kinds of expensive stuff to the engine--helped a bit to smooth it out, but he vibration stayed there until the rear u-joint just in front of the diff was replaced--shazzam--smooth as a "you know what"!! :D
jauguston
Retired
Bellingham, WA
JD,
Your vibration sounds just like mine. Try making a shim to go under the rear trans mount. I made one out of a piece of 1/8" X 2" flat bar. It helped a little. Talk to GV tech support if you haven't. If you find a total cure let me know what did it.
Jim
metrojd
Pittsburgh,Pa
GV Vibration
JD,
Jim
Jim,
I will try the shim aproach.
I am thinking of getting a 1 piece shaft made.
Thanks
John
tonkadoctor
none ya bidnes
Get your hands on a u-joint tool that you can use an impact wrench with or get your paws on a hydraulic press.
A little silikroil;Sweet or PB blaster wouldn't hurt on that rusty stuff either.
Exekiel69
If You have a ball Joint removal/install tool it works great too convined with an impact whrench.
adrianspeeder
USAF C-17 Avionics
Air Force
Thanks, Harbor Freight has one for 35bucks and I'll pick one up when I get the second ujoint tomorrow.
I was talkin to 4x4truckingirl yesterday right when I finished the cleanup and without thinkin just said, "I just finished paintin my shaft."
awkward silence...
jauguston
Retired
Bellingham, WA
John,
If the total length of a one piece shaft would be 5' or less you can do it. Mine would have to be longer than that and my understanding is 5' is the longest a driveshaft from yoke to yoke should be.
Jim
subway
be nice to the admin :D
York PA
awkward silence...
smooth, real smooth :rotflmao
4x4TruckinGirl
"Cowgirl"
Dixon, MO
actually.... i think it went more like..... "i just got done paintin' my shaft"... silence followed by " wow, you ARE a special one" cookoo :***: then there was talk of paintin' it black.... and then yeaaaaaaaa..... :rotflmao
im just messin with yeaaa LOL
metrojd
Pittsburgh,Pa
You are right
John,
Jim
Jim,
I called a driveshaft co. I have delt with in the past.
The shaft would be 6'2" +/- and he said no way.
Even going with a bigger tube he said no.
I guss I will do the shim deal.
thanks
John
truckonfire
