well when i got home from work today, i decided to take a short video of the first startup of the day and let everybody have an opinion about it. the temp was about 45 degrees or so outside nothing real cold. when you first start it up its not hitting on all of the cylinders for about 5 to 10 seconds after startup depending on how cold it is. all the gp's are in working order so I'm ruling that possibility out. not realy sure if its injectors or bad timing and cold weather cause it sounds like its coming from both sides. heres a little sample.
http://s265.photobucket.com/albums/ii229/the5taters/?action=view¤t=SDV_0169.flv
