and aanother ebay find
rjjp
Needs to go test
Clare, Mi
It's a tag axle, that's the way I would set one up, stock maneuverability empty, and the extra rubber when loaded... Plus there is no reason to scrub the extra tires when empty.
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
there is a truck in town that has the same setup. he hauls grain with it and it is 4x4.
Puller
Puller
Lapeer, Mi
I guess its cool but what's the point? Carrying capacity of adding an axle doesn't increase the trucks GVW or GCWR unless Fords willing to uprate his ratings so it still could be overloaded. Looks like a super clean truck though and like the thought that went into it.
gunz
Yukon Oklahoma
Yip. still just a 1 ton, Just a ton of extra expense in rear tires now. This is why morons should not own trucks.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
You make a good point about an extra expense in tires and whatnot, but FWIW, it's not a 1 ton...he has the ad mislabeled. It's actually an F-450...note the badges and the 10-lug axles.
Also, even though it doesn't legally increase the truck's GVWR or GCWR, it should help the truck to be more stable...that's never a bad thing ;Sweet
GreenDiesel
Austin, Texas
I suppose you could register it as a farm truck to allow loading over GVWR? I think it works that way, if you have a farm
Lance
