94' F350 w/ 7.3 K engine - anyone own one ?
OnDaRoad
On the road ....
Dayton, OH
Anyone own a 1994 F350 CC with the original & unmodified 7.3 factory K turbo engine ?
Final assembly was in Kentucky .......
The biggest improvement and most sought after option for 1993 was the introduction of the first factory turbo option. This option was available for the two remaining years of IDI production and is significant for several reasons. From the very beginning of the 6.9 liter production, a turbocharger was considered, but the normally aspirated engine was already a $2000 option and the addition of the turbo would nearly double that figure. Many believed that the extra amount on the sticker in the mid ‘80’s would put it over the edge price wise. Luckily, companies such as Gale Banks Engineering, Advanced Turbo Systems (ATS), and Hypermax saw this as an opportunity. ATS was chosen as the turbo system provider for the new factory turbo option and Ford/Navistar implemented other engine upgrades to compliment the addition of the turbo. Trucks equipped with this engine option can be identified by the small “Turbo Diesel” emblem under the F250/350 front fender badges.
The additional engine changes are as follows:
Cylinder head gasket heavier ring and armor wrap
Increased wrist pin bore on connecting rods
Larger wrist pin
Anodized piston head
Keystone design top and intermediate piston rings
Increased number of oil passages in oil cooler (30 fin/inch vs. 24 on NA)
Turbo specific flywheel
Turbo specific vibration dampener
Turbo injector pump
Turbo injectors
Modified injector fuel return line routing
Modified E4OD dipstick
Modified E4OD turbo micro processor
Turbo specific cooling fan clutch
Lower restriction exhaust
Additionally, the truck received a slotted front bumper and an air dam below the radiator. These improvements conservatively raised the power output to 185hp and 360ft/lbs of torque. These numbers are believed to be under-inflated so as not to downplay the mid year introduction of the new diesel engine.
Jim
94f450sd
somewhere,ma
Ive had 2 of them.94 f super duty and a 94 f350.the SD also had the turbo diesel emblem under the super duty emblem
idipwr
Ohio
I ordered my 94 in the fall of 93 and took delivery in feb of 94. And yes the 93 in my sig I sold had that motor as well.
94f450sd
somewhere,ma
Thanks Rich ....
Any problems with either engine ?
Jim
The super duty had it replaced at 200,000 miles.I bought it with 240,000.sold it with 340,000 on it.only problem I had besides ip and injectors every year was it had a skip I couldn't track down.I think when they did the emissions test on it they bent a couple valves.ran fine with awesome fuel mileage before the test.skipped with horrible fuel mileage after.loved it always started.never plugged it in, didn't have a block heater.I honestly had very few problems with that truck.
Although I do like the psd much better.id snatch up an idi if one came around.
RANOVRU
Virginia
Yeah the ratings were 190/395 for the turbo IDIs and 185/366 for the non-turbos.
I think anyone in their right mind could tell those #s were underrated. Turbo (plus all of the enhanced supporting mods I was unaware of until the OPs article) = +5hp LOL!
Diesel_brad
Dunce
gilbert pa
I believe the stock numbers. A stock 93/95 factory turbo truck were NOTHING to rave about. A lil turn of the fuel screw made a world of difference. That and doing away with the factory turbo outlet and DP too
Rot Box
Northern Utah
Lewiston
Hope I'm not hijacking :eek: I knew about the other differences mentioned, but I had no idea these things were different/upgraded. I'd like to find the upgraded oil cooler ;Sweet Does anyone have any specs on the fan clutch?
OnDaRoad
On the road ....
Dayton, OH
Fan clutch looks the same .....
Fan & clutch look to be the same ....
Jim
ADV
Wisconsin
I have a 1993 F350 CC with a factory turbo. When I bought it I was told it had a bad cylinder. I had the truck running long enough to drive it into the shop so maybe all of about 2 or 3 min. I don't know about a bad cylinder but I know it has rust hole in the oil cooler and pushed out almost all of the oil in my drive way and in the shop in the few minuets I had it running. I am now in the process of putting a NA 7.3 engine in it.
George D.
Las vegas
I have a 94 350 cclb used to have the factory turbo 7.3 then the block seal the po put in gave out and I lost the motor to cavitation now it has a low milage 6.9 with the turbo 7.3 dressings
