'92 7.3 IDI epump question
RBaillargeon
Arkansas
Have seen two different write ups that contradict on how to wire the relay for a new duralift, and im just looking for clarity so i dont burn anything up as wiring is not my strong suit..
#1
Pin 30 constant battery
Pin 87 fuel pump power
Pin 86 chassis ground
Pin 85 key on key off to fss
#2
Pin 85 Ground to chassis
Pin 86 key on key off to fss
Pin 87 to fuel pump power
#1
#2
Either way will work. 85 and 86 are the relay coil. You can run key on power through the coil either direction, it will not care.
