7.3 fuel return woes
Idaho Outlaw
Nampa ID
I have a 93 7.3L IDI. I have had the truck 7 years and have replaced the fuel return lines,fittings,caps, and seals twice. Both times I started to develop fuel leaks within a few months. Is this just something I have to just continue to fight. First fuel return kit was one ufrf ebay, The second kit was from IH. Is there a better kit, updated parts, trick:confused:s, etc?
ADV
Wisconsin
Something good like a billet aluminum return line cap?
H there was a guy who was machining some brass ones, but those where very expensive and he didn't go far with them sadly and as hard as I have tried he just does not respond to PM's
I am glad I kept and used the original caps when I did my truck several years ago.
I know little things like this can be aggravating, but it's not rocket science. I would get another kit, or another set of o-rings(tractor supply has them in their hydraulic section) and carefully take the old ones apart. Look the o-rings over carefully and see if they show signs of being damaged. Look inside the caps and see if they look rough or out-of-round. The o-ring simply seals against the injector and the cap, whatever is causing them to leak should be obvious.
pwillis
