671 detroit swap??
bghnkinf350
Bay Area, Ca
A 6-71 swap would be awesome, except for the physics of just trying to fit it into the truck! You would likely be better off finding a med duty frame with one and putting your body on it!
hesutton
The Anti-Anderson
Bowling Green, KY
The 6-71 is huge! It weighs 2100+ lbs! And is 54 inches long! That would be hard to squeeze into a F-series truck.
Heath
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
It's been done, unless this picture was Photoshopped ;Sweet
The 6-71's been efficiently converting diesel fuel into noise since World War II :D
88beast
pa
or a 653 or 6v71 the 6v53 is a common one as detroit swaps go
anyone think an 6l53 the flat coach bus version?
Diesel_brad
Dunce
gilbert pa
great vids brad....how would one of these stack up to a built idi or dt360?
Not even comparable. A dt360 can be built to OVER 1000HP with STOCK parts. Just a IP and turbo is all you need. Those Detroits were PATHETIC. Any one I have ever driven is UNBEARBLY loud and will not get out of its own way. They are only good for one thing in my book, a boat anchor
The Warden
MiB Impersonator
I have to disagree with that. I've never dealt with a 2-stroke Detroit in a land-based application, so I can't comment there. However, in my experience, they make great boat engines. They're essentially designed to be run at or near the governor constantly, which is perfect for a boat at cruising speed. For the same reason, they also make good power generators...I can't remember the last time I was on a boat that didn't have a 2-71 generating electrical power (except for one boat that has marinized M-B OM616's).
The fact that parts for them are dirt cheap and they're simple to repair, only helps their case IMHO...I admit that I have a soft spot in my heart for the 6-71 (I cut my teeth wrenching on one at age 14), but I firmly do believe that they have a place in this world.
I also admit that I'm curious to see how they would do on the road...I haven't given up my idea of someday finding a 6L-71-powered Crown bus to play with :angel:
Diesel_brad
Dunce
gilbert pa
Just look at any hill(not even a mountain) and start downshifting. NO BALLS.
They make a N/A IDI towing 10,000lbs look like a rocket ship:rotflmao
