1986 Ford F350 T19 Transmission HELP !!!
Logan G
I took a star bit bolt out of the driver side of the transmission because it was loose, now i can't get the bolt to go back in and my truck won't pull. what do i need to do to fix this issue
Here are some pictures of the bolt, I can post the location of the bolt if need be.
Trevtron
Katy, Texas
I don’t know but this may help ya.
Ford420ci6point9
Stafford Spring CT
So it just won't screw in? inspect the threads in the hole and see if they are stripped you may be able to get a thread chaser or tap in there and clean it out and straighten it, or at last resort you could helicoil it.
olsen726
