ZF6 from 7.3 P/stroke to idi swap
johnkracing
chilliwack bc
I have an opportunity to grab a zf6 from flywheel to tcase incl starter clutch pedal master and slave cyl. My question is what parts wouldn't be usable in the replacement of my E4OD
Thanks in advance
rhkcommander
Oregon
Its been done a couple times but you'll have to search.
Takes a lot of modification to work, its not like a zf5
The flywheel for sure won't work. The PSD uses 10 bolts to hold the flywheel to the crank while the IDIs use 9.
johnkracing
chilliwack bc
Thanks guys, not looking for a complicated project so I'll either go with a zf5 or put in another 4R100 modded to work with the semi retarded controller in the 94
rhkcommander
Oregon
Yeah from memory the gear spread wasn't much better than the zf5 anyway, just better spread.
I'd rather get an over under auxiliary with the 5 banger if you need more range
Kevin 007
Full-floater
Nelson BC Canada
Ya the ZF-6 has a lower 1st and reverse, which is nice but not really worth the extra work IMO. If yours is a 4wd, you can use LO range when you are in tough spots and need a lower gear
