MidnightBlade
Shiftin' Smooth
Well, started to tackle the tranny swap today and met up with a major problem.......The tranny is still attached to the truck . I have all the bellhousing bolts out, the T-Case removed, and the crossmember pulled. As of right now the floor jack and sme other unknown froce is holding the tranny to the engine . Do you have to pull the starter to drop the tranny or can it just stay there? Also what all else is there to be removed? I also already have the clutch cylinder pulled. Do I have to pull that metal tab that it pushes on too (I have no clue what it's called) or can that stay in there?
