trackspeeder
Stone crusher.
nope none of the gears work! and i didnt think of that!
Broken input shaft or stripped gear set. Unless the tranny was rebuilt with upgraded parts in the past. This will be a pricey rebuild.
I was thinking that too. Might also be the infamous torque converter explosion. Those tend to go when pulling away from a stop (possibly right around stall speed when the fluid hammer effect is greatest).
The upgrade for the input shaft and 4 pinion steel overdrive planet can be had in the range of $100 though so the upgrades aren't all that expensive. I've seen the steel 6 pinion forward planet for $60 a while back.
Just changing the input shaft and gear set is a start. Might as ell replace the rest of the out dated crap inside. Thats when the price starts to climb quickly.
