WMO seperate antifreeze from oil
93cc7.3
needs turbo power
plainfield IN
as the title states is there a way to seperate a very small amount from a 55 gallon drum of used oil
Draw the oil off the top, the anti-freeze will settle to the bottom.
3/4 Ton-O-Fun
90F250 na7.3IDI 4x4
AZ to BC
Disclaimer! I have never done this!
If you have a good way of separating water, just add a bunch more and stir. This should form two layers with standing and be easy to remove.
Test it out with a small quantity first.
Chemistry tells me this is right, not any actual experience with used motor oil mixed with antifreeze.
93cc7.3
needs turbo power
plainfield IN
thanks franklin2 i kinda assumed that it would separate like water but was unsure and 3/4 i don't have any great way to separate water just settling and a few fuel/water separator filters
itsacrazyasian
residentcrazyasian
boca raton, fl
it'll settle out to the bottom. One of the idiots that works for me dumped antifreeze into my wmo/watf container. I waited a few days and could see a seperation in the two so i sucked off the top till i got within a few inches of the antifreeze and dumped the rest.
placidoert
