mudslut350
okay so im about to purchase everything and set up my wmo filtering setup but i have a couple questions i cant seem to find answers for. first is how long are your filters lasting before theyre plugged up? ill be using a 10 mic water seperator and a 2 mic filter. second i have two 55 gallon barrels of wmo long story short they each have probably 2-3 gal each water in them. they are closed top . i dont know how to get the water out easily. i need a small petcock type valve in the bottom is what ive come down to so not sure how to install one as its closed barrels. im thinking about filtering out about half the barrel first into clean barrels then plug them back up after that tip barrel with contaminates on its side drill a hole big enough so the petcock can thread into the sheet metal and jb weld the threads and thread it into the barrel essentially holding it by the threads and jb the outside. also from my settling barrels to clean barrels the oil should be water free am i correct? or should i install valves on the bottom of clean barrels. any help would be great thank you!
