Wire harness, headlight conversion.
Exekiel69
I have this on my headlights for a while now, and even though they are really bright it might have make them brighter. Now help me out here, with this conversion I dont have any more problems with the headlight switch right? btw that is wy I got it on the first place.
Thank you.
ericboutin
Boiling Springs, SC
Are you talking about the whiter, brighter headlight mod?? If so then I must say I had a ton of problems with my switch before the mod...now that I've done the mod (about 1 year ago) I've had no problems with the switch. I'm definately thinking I may still do the running light mod just to be on the safe side and know that I will never have to worry about that dumb switch again! ;Sweet
Exekiel69
Ok, so the harness does not fix the switch hazzard. It said's supposed to take the load from the switch but I allways wondered if it really does fix the possible problems with the switch, no I know.
Mikes91
Melbourne, FL
Are we talking about the same thing? The headlight mod--"Whiter Whites, Brighter Brights", is supposed to take the load off the switch. I don't remember seeing anything about a wiring harness in that mod, though...
EZ, putting relays on the headlights, and running lights, will take care of all possible problems related to the headlight switch.
Exekiel69
Thank you Mel :hail that's what I needed :D .
Mike, I did not wanted to start asking questions in your post since I did not even know if I was right, so this may also help your problem with the switch?
soulpatchfr
goat herder
norfolk, va
Mike,
i believe that LMC, & i know that Summit both sell a harness that replaces the OE headlight harness under the hood - relays are built into said harness :Sly , so i guess the mod is much easier - give me a minute to find that thread...
the running light mod will still be neccessary, but it's something i'm looking in to, myself. you should, of course, still R&R your switch.
Mel - i think the running light mod is in our Tech section, but not the HL article... who wrote the original? has anyone taken pics of their Summit harness mod? hint, hint...
soulpatchfr
goat herder
norfolk, va
ok - i found the link in the FAQ's
i had a LMC p/n listed in a thread i created - click my name & check 'all threads started by' or whatever that says...
let me know if you find better info - i'll be right behind you. not having problems, but i don't want to have them later, either.
as i told Ron earlier, i plan on upgrading to all LED running lights soon, so i hope that'll cut down on amp draw tremendously ;Sweet
zigg
Victoria,Canada
Soul
I'd be a bit careful about that if you plan on also replacing the taillights with leds, I've heard that they will not shut off your cruise control when replaced with leds when you hit the brakes...
Just a thought...
Zigg :)
soulpatchfr
goat herder
norfolk, va
zigg said:
Soul
Just a thought...
Zigg :)
Thanks, Zigg.
unfortunately, she was a simple vinyl floored 'Custom' trim package, so i don't have cruise. We even talked about that, but that darn Nextel connection is a nightmare ;Really & i'm not sure that either of us are positive about the rumoured bad effects of switching to all LED's.
if you can elaborate, that'd be nice...
i remember reading that if you left a few regular bulbs (i was thinking the license plate lights) that you'd be OK, Ron seems to think that the ABS system is also/instead a problem, & the tail/brake lights would give me troubles.??? wasn't it only on the granny tranny's?
i know somebody over at TDS has tried these things...
i'm willing to be a guinea pig - at least starting with the front markers & cab markers (already have my new side markers in.
Magoo
Blind Brain Surgeon
Southern Oregon
Put LED tail lights in my 91 and now the anti lock brake light comes on after about 5 minutes of driving. I had forgotten about how the (3157?) bulb is required to make the anti lock work. No one ever explained to my satisfaction why that is. There is less than a volt of current on the brake light wire at all times. It is not enough to lite the incandecent bulb but it will light 3 of the LED lights in each lite. LEDs are nice and bright though. Brighter then the factory back up lights. :Sly
The loom you folks are talking about from Summit (maybe), is that the pig tail connnector for the headlight switch or is this something else?
Exekiel69
Here is a linky, or you meant already installed?
Either way it is awfully easy to install it, it comes with fuses on the hot wires too. All done nice and clean ready to install. Too bad it shows N/A for now I guess.
gabbyr100rs
Acworth, GA
Check Summit on line--the old harness part number that is no longer in stock is crossed to a new replacement. Worked pretty well last weekend. Wired it in behind a fuse block. Fits well on the passenger side wheel well.
Lights are brighter, and will be good to take the load off the switch--don't need to melt another one along with the plug!!
