wierd question about ttb
fcdrifter13
Cross Lanes WV
Ok this is gonna sound strange. But I want to swap a ford ttb 4x4 front suspension into my 79 2wd project truck. I am building up a hot rod pumped 24v and will really have no way to hook it up on the street. I also love the lowered look of my truck right now
So I done some looking into the ttb and you can build up everything to hold the power andit looks like I could keep the truck relitivly low. My big question is, is this even a possible swap I know with enough money anything is possible but I mean realistically.
Goofyexponent
Mentally Unstable..
Halifax / Nova Scotia
you would have to measure for the frame width, and then measure the frame width of a current F250.
IIRC I don't think it will work due to the older style ford's frames being narrower....meaning your spring perch would be interfering with your pumpkin on te driver side beam.
MUDKICKR
NITRO WV 25143
i know a guy that lives real close to you that would sell you a 89 f250 dana44 ttb with a reg cab lond bed frame.
fcdrifter13
Cross Lanes WV
Thanks for the frame. Will work great with the plans we talked about. Now on to the next question just how strong is a np203 my neighbor has one that is 31 spline if I counted correctly. Think it will hold up to a hot ridded 24v with a bts e4od?
Diesel_brad
Dunce
gilbert pa
Another issue you are going to have is, the 70s trucks dont have a crossmember under the engine to mount the TTB to, like the 80-97 trucks do
fcdrifter13
Cross Lanes WV
Making some progress
Stock height
lowered.
Everything lines up great as far as the drivetrain goes, but I will have to make some adjustments to the cab mounts.
Lance
Staff online
