Are you running svo? If so, definitely a warm coolant circulator. Enviofuel.com has a kit. Otherwise, a block heater is likely cheaper. I imagine you could even get one at a junkyard.
I will check them out. I think im just gonna get one that goes in the freeze plug. I priced a circulating coolant heater pump and it was 57. But It doesnt stay cold here long so i think the regular block heater will do just fine.
