When my 85 with 6.9 sets up like overnite it will not start unless I bleed it. It does have the electric fuel pump and if you park it down hill it will start. It looks like the return fuel is returning back to the tank,the return lines on the injectors are dry and they was replaced not long ago. Is there a check valve in the system somewhere? Where else should I look for the problem? I don't understand what holds the fuel in the return lines to keep it from going back to the tank,but once it cranks it runs great. Thanks
