thats great to know. im doing a hydroboost swap in the next week.
the play im referring to is that every once in a while i notice that "center" of the wheels is at 1 of 2 different spots on the steering wheel,
If you're still running factory-style steering linkage, that is likely where your problem lies, not with the box. Depending on the condition of the TREs, when the pitman arm starts moving the first thing to happen is the drag-link will twist some amount, only after that do the knuckles start moving. I've seen this behavior on a number of F350s, even with brand new TREs. It does not look like much of a "play" when you look at it (and it's not really play in the typical sense of the word and there is no slop in any of the components), but when you factor in the gear reduction happening inside the steering box that miniscule distance the pitman arm travels while the drag-link is twisting can easily translate to noticeably different positions of the steering wheel.
Apparently Ford recognized this as a problem because later trucks have what is essentially full crossover steering from the factory - the drag-link moves the passenger-side steering knuckle directly, and it in turn moves the driver-side steering knuckle, and since the two steering links are not directly connected the twist in them is pretty much only caused by the suspension cycling and does not affect steering feel up at the wheel.
Btw this apparently is an issue with some Dodge trucks as well, as there is a company out there that makes special 'boots" for the TREs that are essentially poly bushings formed like a cup on one side - then the TRE is installed into the steering knuckle the bushing gets compressed slightly, this stops the TRE from twisting under light steering loads while still allowing it to a bit to correct for axis misalignment and such as the steering goes from lock to lock. That setup is only sold as a full kit tho, and only for Dodge trucks, so for a Ford you'll be on your own. Obviously if you plan on trying it make sure you DON'T put one on the pitman arm joint, that is the one that sees most travel thru its range and having a constrictive bushing may wear the joint prematurely. The TREs connected to the steering knuckles should be a pretty safe bet tho as they mostly turn within themselves instead of "bending" like the pitman joint does when the suspension cycles up-down.
Yup, and unless you do aftermarket crossover steering you're stuck with that behavior.that is exactly what is happening.
i dont find it unsafe, i just find it annoying.
In the meantime, have you properly adjusted the over-center lash? This causes a lot of bump steer. Of course it's exasperated by worn tie rod ends, balljoints, wheel bearings, blah, blah, blah.
I would love Redhead boxes for both of my trucks. They do builds for hydro assist too.
To clarify tbis I would say no they do not...bazed on a few tele conversations directly with them. YUO must PORT uour own box prior to rebuild a s send it in then they will build it.
They do not port boxes as my last purchase for a local customer.
Just FYI for those wanting to run hydro assist steering. It will not be safe if you are running hydroboost brakes. The hydroboost unit reduces the flow needed to use the assist properly. In return your steering becomes VERY slow. I hate it actually on my truck, and will be removing it and my hydroboost. Going back to vacuum brakes using electric pump and full hydro steering.
There is ONE company that for a fee of around 600 bucks, will take your old hydroboost unit, disassemble, open up/port all the passages and install a rebuild kit. After this is done the hydro assist steering will function properly.
With these trucks you don't really need high-steer, our TREs are already pretty high off the ground (as opposed to the newer Superduty steering which are low-riding rock/stump magnets). What you need tho is the crossover part of the high-steer - you need to move the draglink from the center link to the steering knuckle itself, whether with a high-steer arm or in another fashion. The newer trucks have the draglink and the center link attached at the exact same spot on the passenger-side knuckle, just one is above and one is below the knuckle arm. Essentially factory crossover steering, that setup would work well on our trucks with our relatively high knuckle arms. Probably nigh-impossible to retrofit tho...
