So what is the difference between a std F250 and a F250HD? I found out today my 1985 F250 6.9 4wd is a HD...8501-9000 GVW....what makes it an HD? Would it have a TTB D50 or a D44? Suspension or frame differences?Thanks
They were very rare, but I've seen at least one light-duty F-250 that had a factory semi-floating axle (I think it was a Dana 60; it was an '83 or '84 so it was definitely a Dana axle) and a diesel. I wish I had taken pictures of it, but it at least used to belong to a guy on here who doesn't post very often. His handle is "brians". It was also one of the few trucks I've ever seen that had dealer-installed air conditioning; had the non-a/c heater box with the a/c setup separately and underneath it (IIRC), and a York compressor.Just means it's the heavier GVW - AFAIK, all diesels were the HD. 8600 GVW regular cab and 8800 for the extended cab. (or is 8800 the SRW F350???)
Regular cab F250 has the D44HD, x-cab and F350 have the D50. Might have been a heavy duty front end (snow plow package?) option that gave you a D50 on a regular cab F250 but I'm not sure.
Not sure on frame differences and heavier springs.
