What axle ratio? Poll.
Ratio???
  • Total voters
    73
  • Poll closed .
87 F350 CC LB 6.9 t-19 w/ 3.55 but the tag says 3.56
Shadetreemechanic
Monteagle, TN
I thought this was going to be what do you prefer, then I was bummed there was no 3.73 option. I tow heavy with my early zf and 3.55s and it sucks. First is too tall and so is 5th. I have towed heavy with 4.10s, 1st is about right and 5th is too low. I think a late model zf with 3.73s would be the perfect setup. Tall enough first to get going, but enough grunt to stay in 5th most of the time, with 4th there when you need it.
oztinker47
Blocksburg, California
3.55 ratio in mine, have to burn the clutch a little to get it moving when i have a heavy load or towing the RV but its able to manage freeway speed with the t-19 fairly well.
chris142
SoCal
I thought the only factory options were 355 and 410?
79GLIDE
Omaha
4.10, E4OD. 2200 RPM at 70mph and manages 5 ton goose neck horse trailer reasonably well.
lewisstevey7
