Thatoneguy
Hey y'all so I've gotten mixed opinions about this with everybody I've talked to. I've done this before just wondering if it's actually ok or a no go. So basically i recently finally got around to putting the rest of my gauges in. The only one not hooked up is the oil temp. I'm waiting until I'm due for an oil change and then gonna weld a bung on to the driver's side of the oil pan to screw the probe into. What I've done before is remove oil fill cap, pull vacuum on motor for fumes or whatever, then weld. Obviously I would drain all the oil first and let her drip for a couple hours to get as much out as possible. Think this is ok or no? Thanks
