OPERATOR MALFUNCTION TO THE FULLEST!!!!
BAMUTHAF'NBAM!!!
every post ive read said that if you were a tooth off, it would run very poorly!
this truck did run well. started up first time every time even at -9.5 degrees!!!
well here is the culprit!
i put a 5/16 bolt through the IP housing cover so that the IP gear would not move, when i attempted to lift the cover.
broke the seal, lifted the cover up slightly to get the timing gear cover from behind the IP gear housing.
and this is what i found.
looks like 2 teeth off to me.
i was so carefull when i installed this last time i resealed the timing gear cover, guess i wasnt as carefull as i thougtht.
live and learn.
so glad i took this apart today, now i can set my mind at ease!!!
gotta wait a day for new gaskets tho!
BAMUTHAF'NBAM!!!
live and learn.
