Dave7.3
Diesel ******
As my turbo install draws to completion (had to order a new CDR grommet), I picked up an aftermarket water temp gauge for a little more accuracy. Figure I should put it in while I'm wiring up the pyro and boost gauges anyway.
I had some recommendations from other folks that told me to go ahead and pull the temp light sender and replace it with my aftermarket one on the driver's side head. That wasn't a problem...except the never before seen check engine light has come on.
Now, I'm led to believe that it has come on since I swapped out the temp light. To get it to go off, should I just tee the thing in there and call it good? At the same time, I could just plug it back in and tee off the temp sending unit. Would that be possible or would it bring an adverse effect?
Any suggestions or advice are welcomed, thanks fellas.
-Dave
-Dave
