water port?
I need to use the head mounting bosses for something ive got up my sleeve.
however, I got a pipe plug in the face that I need to work around one way or another.
I have never pulled these plugs.
*** are they?
circled in red.
Clb
Another old truck
nannyfornia
Kenuder valve blanking plug....
OIL GALLEY ????
FUKKIFIKNOW
What about the ones in the rear of the head?
That is the oil drain back area of the heads.. Its a great location for any oil return like from a bypass oil filter. Usually very hard to reach because of brackets. BTW the rear of the heads have this same plug. So you have 4 ideal locations for secret stuff... Want 2 more main oil gally ports for clean pressurized oil..Look under the oil cooler bundle. There are 2 1/8 inch pipe plugs... Might be hard to remove too...
so.... how well would these not work for turbo oil drains? LOL
pelky350
Springfield, OR
The alternator is so shiny why would you hide it down there?? I feel like maybe twin turbos on going to be mounted to the front of the heads and that's what you want this pipe plug gone for?? Lol
are you following my conversion?
I actually just ground them down flush, figure if their just drains, ill never need them.
junk
Paullina, IA
We had a Uhaul 22' moving van with a 7.3. It had an oil fed air compressor that fit on that location and used those drains in the head to return the oil back to the engine. That compressor had a pretty good sized oil feed line to it.
My only concern for using it as a turbo oil drain is size. Most people want like a 5/8 oil drain line. AN fitting there would be -6 max.
yea ill be using the stock fuel pump hole.
olsen726
