I've got a low-freq vibration in the 91 5spd 4x4, between 60-65. It's still there with the clutch in, and with the tranny in neutral.
Here are a few things that -might- be related...
On the way home from buying it, a month ago, I noticed that when it would go torque-neutral, i.e. the grade was such that it was just floating between accel and decel, it would "kick" now and then. I could see the shifter twitch...and the higher the speed, the harder it kicked. At 70, it felt like the truck itself was getting kicked. Kinda worrisome.
A couple weeks later, we had to use the truck to pull a trailer for hauling a car home. On that drive, it started making a little screechy noise under load. Kinda like an angle-grinder on sheet-metal...
Mikes sez "it's a U-joint", so I went and picked up a pair for the rear shaft.
I was driving it over to Mike's place to change 'em out, and noticed a vibration/shudder when I first got onto the freeway. Not horrible, but could definitely feel it.
When we pulled the driveshaft, the joint at the T-case had broken needles in one cup, and a pile o' dust in the other... In fact, the end-piece that slides into the t-case looks discolored over the few inches nearest the u-joint.
When installing the new U-joint at the rear end of the shaft, we could not get the C-clips to go in easily. By really wailing on it, we did get the clips in, but the joint wouldn't rotate freely on that arm. Didn't like that at all, so we pressed the joint back out, and checked the new and old joints with a caliper. The new one was .045" longer than the old.
Hard to believe they make 2 joints so close in size....but this one didn't look "mis-made" either. Nor could I see how the yoke could be bent. It's got a lot of metal in that area....and no signs of impact or other damage.
We ended up hitting the ends of the cups with the grinder...taking .025 off that little 'ridge' on each cup that runs around the outside edge. Reinstalled it in the yoke, and it felt good.
Anyway, I thought all my driveline problems would be solved, and the screech is, and I think the 'kick' is too; but the vibration/shudder is NOT.
If it's not the rear-shaft, and not the tranny (tried it in neutral, vibe still there), what the heck is it?
Didn't Zigg once have a hard-to-find vibe that turned out to be the T-case?
Mine has dried out goo over a lot of it...so maybe something went wrong there. I've heard of the pump coming loose inside....that sounds like the kind of thing that might throw fluid out of the breather hole!
But the fluid level is OK, and it's ATF. T-case seems to work fine.
One final 'symptom'... I've noticed at some speeds and/or pedal-settings, I'm hearing sort of a 'hiss'. If I press the T-case shifter forward a bit, that hiss (I -think- it's the same noise) gets more pronounced, and a little harsher sounding. If I pull back on the lever just a bit, the noise seems to stop.
I don't remember my '86 ever making a noise like that...
So, am I looking at a new T-case? Or is the vibration/shudder something else?
I also have DMF/clutch issues, but this shudder is always at 60-65 mph, even in neutral and/or with the clutch in and engine at idle.
Richard
Richard
