Van vs truck PS brackets
jayro88
Auburn IN
So the power steering bracket on my ‘88 e250 7.3 broke. The metal actually broke.
I was wondering if this bracket was the same on the trucks vs the vans. Right now I really don’t have time to mess with it, so I am going to take it in to be repaired. The PS pump was also leaking, so they are going to replace the pump and bracket for $270, but I would need to source the bracket. If they have to it would make the cost go up etc.
Anyone have a bracket they want to part with or a good source online to order it if it is still available?
Thanks
Oledirtypearl86
Whitehall MT
If the brackets are the same on the van as on the truck I have one I'll send you pm me and I'll get it tonight if it will work
jayro88
Auburn IN
I sent you a PM. It maybe something you should take a picture of and post for comparison. I am still looking, but a quick search is showing that they look different.
Oledirtypearl86
Whitehall MT
So this is a power steering pump bracket of of a pickup does anyone have a pic of one off a van
They are different. The few vans that I've seen use the Saginaw power steering pump like the Chevys did.
I'm not sure on the bolt pattern, but I believe they are made out of steel and look different. I haven't seen one in a lot of years.
jayro88
Auburn IN
Looking online, this is what I saw. I am gonna double check tomorrow.
jayro88
Auburn IN
I just went out and checked on the old 84, and it has a thin steel bracket for the sag pump. I hope this helps you.
Thanks for checking. That is what I have too, so it looks like the truck one is not compatible.
Anyone with a van one?
RDieselKid84
Mississippi
That is a Van,E350 The frist 6.9 we special ordered it new to customize. It went all over the US , Canada and Mexico when it was safe to go there.
