V 10 tranny cooler advice needed
Glassdude
Sonoma, CA
I decided to change to the V 10 tranny cooler when I replaced the tranny. I can't seem to get the fluid lines hooked up. :confused: Boy it's a real ****** just to get to the thing. If anyone has done this I could use a few hints.
Mike
sassyrel
iowa
dang man--on the 96 stroke--i took the excess brackets off--put a piece of rad hose on the center bracket--zip tied it there in two places---and on the right side by the line hookups--and hooked up the lines--mine were 5/16--but i got them over the 3/8 ones by putting lube on them--and used worm drive clamp--no leaks--and no more hot rans and leaking front seal!!!!!!!!!!
Cv axle
