david85
yea you can have them bored out but its limited to compressor housing/wheel size. its not that universal. i think we need a bigger housing than what we have now. David didn't you have yours bored out to fit that 60-1 wheel? Could you go any farther than what you did on boring it out?
What happened was I bought a new compressor wheel and housing from typ4 and the compressor housing was custom bored to fit the wheel. Not really sure why that was done instead of simply using a properly fit housing off the shelf. Maybe Russ figured it would have been too big to fit in the truck?
david i think you should try changing you exhaust turbine to something in the .85 a/r ratio and see how that works for you. with the current turbine you are majorly choking off that turbo at higher rpms.....
I currently have a P trim turbine wheel which is the larges one short of going to a "big shaft" accorting to this: http://www.turbocharged.com/catalog/twheel.html
All this time I thought my turbine was too large and not spinning fast enough to properly spool the compressor. I am seriously confised now.....
