David your math is on the right track but your numbers are wrong. The reason you have such high airflow is because you ran your numbers assuming the engine had a volumetric efficiency of 100%. We calculated that these motors are around 66-69% efficient and there for would mean at 15psi there would be around 35lbs/min of airflow. now graph that at 2.00 on the PR and you'll see a much better looking value.
honestly these numbers are as close as we can get but to be truly accurate we need to get an N/A motor on an engine dyno and do some airflow testing. my airflow numbers are at 3000 rpm but you can do some math to figure out what the airflow is at at each rpm depending on where you want to see your boost goal.
Uhuh.... so that confims it then. The compressor I am running is easily the worst of the ones mentioned here so far
Plotting your numbers puts it outside the efficiency range on the surge side of ideal.
The cummins turbo and the T61 look great though.
Here is the H trim just for reference:
Seems to be very close to the 60-1 but can't flow as much. Which seems to match what the experience has been so far. There is more power, just not a lot of extra boost in the gauge.
So sootman, what exhaust turbine did you have in mind?
EDIT: thanks for the heads up on the VE specs of the engine. I had used 85% in previous calculations but it seems thats still way too high.
