Decided to keep the mech oil sender tube plugged into the factory sender location because I already had the hardware to do it.. So, does anyone know if these two oil ports under the cooler are both pressurized, or if one of them is a return? Since I still have the engine on the stand, it will be no problem plumbing one (or both?) of those for turbo oil supply.
http://i138.photobucket.com/albums/q263/coreyzak/oilports.jpg
I think I'm going to go ahead and drill & tap the manifolds for the EGT sensors at the same time. I've found a good price on a unit that will accept and display two inputs simultaneously,
http://www.auberins.com/index.php?main_page=product_info&cPath=5_21&products_id=357 and use two of these-
http://www.auberins.com/index.php?main_page=popup_image&pID=182 with the 1/8 NPT adapters that they have for them.
Since I was a ******* and didn't pay attention when I put the new turbo heads on, I got them on opposite sides and had to swap plugs, nipples and sensors over, this was no problem until I came to the 9/16" 4 point plug in the passenger side head where the heater hose nipple should be. I was limited in what could even reach it, nothing worked. I ended up welding a 3/4" hex nut onto the top of it, needless to say it came out. once it was out, I went ahead and finished the weld then cleaned it up a little.
Got the new glow plug harness made and installed, oil cooler removed, cleaned, painted & resealed, finally found the harmonic balancer so I was able to get the pulleys back on and found the right 5/8" hose to use for the breathers and catch can/recirc line. Hope to have it back in Henry this weekend...
