truck won't start after ac12g plug install
skintbackfarms
AL
Just put in those ac12g glow plugs and the truck won't start. The WTS start comes on for only a second thats it. The controller just clicks away. Any ideas on what it could be? Thanks
david85
Campbell River, B.C.
Did they ever work with the factory controller?
Could be the controller is confused by the different glow plugs.
skintbackfarms
AL
The truck had 6 champion and 2 autolites in it. It would crank but it would take a couple of seconds. The controller worked as far as I know. I guess a might wire a switch into and see if that is it.
f-two-fiddy
Duluth, Mn.
Check the plugs for continuity.
You need to get those plugs out and get some Beru's. Type Beru into the searchbox.
skintbackfarms
AL
Just bypass the controller and put the switch in the cab. Held the button in for 5 seconds and the truck fired right up. I just the controller could have been bad along with a couple of the glow plugs. Its fixed now. I will find out in the morning if it works good. Going to get cold. Thanks for all the help. The AC12G plugs are the ones I am trying out to see if they work.
f-two-fiddy
Duluth, Mn.
FWIW, to My knowledge, no other plug, besides Beru's, and High buck Marine plugs. have proven not to swell.
So if You feel confident, keep running them. Most won't take the chance of them swelling, breaking stuff.
LCAM-01XA
my very own hell
FWIW, to my knowledge I have a set of 8 AC Delco 12G plugs sitting in a cardboard box right about 4ft from me, they have been glowed for a few minutes at a time on several occasions and are presumably dead, however they don'r show even a sign of swelling. I'm just saying...
GenLightening
Yeah, it's a CHEVY!
Pukalani, Hawaii
That's how they keep them from swelling, short life span plugs! :rotflmao
Alex S
Jeoff
New West BC
david85
I am a glow plug snob as much as the next IDI guy, but if I could find a TRUE self regulating dual coil glow plug than I would consider getting one or two for testing.
HammerDown
Glenolden Pa
Heck I would just get 2-more Champs.
I ran them for the better part of 15 years with great performance and great cold weather starts!
skintbackfarms
AL
I JUST WANTED TO TRY THEM OUT. The truck had 2 autoshits and 8 champions in it. The 2 autoshits was burned out and swollen and 1 champion burned out and not swollen. No telling how long they have been in there. I put the AC12Gs in there to try them out. I have nothing to lose doing that. It might be a cheaper route out than buying the BERUs. I had to wire the controller up, but still, if they work it would be better than spending at money YOU don't have to. I got them for 9.84 each SO WHAT!
david85
You can get motorcraft/beru glow plugs in the $10 range with ford logo on the plastic bag and everything....
Alleycat
