spyder1100
I know on the 7.3 they won't. Not sure about how the 6.9 controller works, but I would assume they would. The 6.9 plugs are self regulating, like the AC 60G and the Autolite 1110 I tested. The replacement 6.9 are still 6 volt plugs tho. I would assume you could still use the 60G or the 1110 in the 6.9 since they are also self regulating. You'd just be using 12v plugs instead of 6v. They would have to heat a little longer, but would take alot more abuse. Down here in North Carolina it doesn't get as cold as it did when I was up north, but at 15 to 20 degrees outside without the heater plugged in, I run my 1110's for 15 seconds and she fires first time every time. Not too bad for a truck with almost 290k on the odometer. On a side note, the 60G did get hotter than the 1110, but it burned out when I hit it with 18v. The 1110 didn't burn out even at 24v. Granted our trucks aren't going to see anything like that.
