Silver Burner
Burnin' Oil&Rubber
For the last few thousand miles, it doesn't matter how cold the weather got (except for the one day in central Oregon when it was -7), the truck would fire up no problem after a 10 second or so wait on the controller. In the last 500 miles though, it has gotten hard to start right away. It still burns for a 10-12 second run followed by that quick flicker on the wait to start light, but it'll just turn over a few times, catch, then immediately die. Then I'll wait 30 seconds or so, run the cycle again, and crank probably 10-15 times until it finally catches. When it does, it acts like it's running on 5 or 6 cylinders for a few seconds before they finally all start firing and it calms down and runs like the perfect truck it's been. My question, *** is going on? Do I have an air leak in the fuel lines somewhere? I did verify at the top of the fuel filter assembly that the lift pump is working with a home made air valve attached to a hose running to the bleeder. Cranking the truck produces a bunch of diesel out of the line. Any help would be appreciated.
