Trim Holders and other stuff
VandalS
California
I’ve just about finished the body swap and lift. But in the move some of the trim popped off. Is there a place to buy the plastic piece the mounts between the body and the trim?
The other question I have is if it is worth it to swap my axle out for the same axle w/limited slip? Same ratios and the LSD feels like it has less slop in the gears based on rotating the pinion back and forth. Not sure on the number of miles on either axle and have only driven the axle that is currently in there.
snicklas
6.0 and Loving It!!
Staff member
Greenfield, Indiana
VandalS
California
I’m talking about the trim on the outside of the truck that is about 2-3” tall.
Sent from my iPhone using Tapatalk Pro
typ4
Newberg,OR
a company named Auveco makes trim clips. Also our Napa has a huge binder with samples of all the clips they supply.
