ez-
neither has a built in thermostat. I robbed one off a '92 Dodge pu that had cooler/fan/thermostat built into one unit.
'92 w250 4x4 5.9 non ic, TF727. the thermostat control drives up the price majorly.What is a dodge pu (pick up)? I'll see if I find one of this then since the thermostat is kind of obvious that is necessary, don't understand why they sell a cooler and a fan with out one.
Thank You.
I found a very complex transmission cooler system on this truck. it had a warmer, cooler and external cooler. the line dia was 1/2" too. dodge really took regulating the temp on this trans very seriously. you can see the external cooler located just right above the AC condenser in the first pic. the second pic is the warmer.Is this a factory thing or aftermarket? I searched rock auto for a cooler for a dodge 5.9 non ic but they all look like a regular cooler, no fan or tstat.
Hey EZ, Here is my setup, the temp switch is a separate unit, you can see it in the pic. I bought it at a speed shop up the road from me. It works great!
Why can't you just add a temp switch?
