Hey, that's a nice looking unit, Darrin. Question: It looks like you mounted it horizontally, right under the tranny, is that so? After doing it, would you suggest any other place? Do you have a tranny temperature gauge, and did you see any difference before and after?
Thanks
Thanks, It is mounted under the truck sort of under the rear part of the cab. The Trans you see in the pic is the Gear Venders OD that is after the TCase and trans so it is back a ways. I run the trans fluid from the stock radiator, to a Super Duty Tranny Cooler in the front of the INtercooler, then it runs back to an aux bypass filter then through the trans cooler with the fan on it, and back to the trans. As far as location there is really no other place that I could install it and it works awesome where it is.
Hard to tell in the pic but there is about 3 or 4" Of clearance from the top of the cooler to the bottom of the floor board so there is plenty of ventilation.
I do have a Trans Gauge, with 2 senders that I can switch back and forth, One is in the trans itself, the other is on the hot line going by the aux filter. My trans gets as warm as 180 Deg, and that is about it, no matter what I am doing with it. When I switch it to the hot line I usually see abut 20 deg warmer. It works Great!
EZ,..Looks like you have plenty of options, if you can get a whole setup for about $200.00 Thats not bad, I still have to check my speed shop for you and see what I paid, but mine were 2 separate units.
Now that I have this setup, I would not buy one without the auto temp switch!
