Optikalillushun
ya know, it just might. add in the other thread about a shift kit and some members rebuild experiences (david85 for one)...hmm
Got the cooler installed today.....low speed driving I saw as high as 190F and at highway speed 65MPH it went back down to 175F.
So far its looking good....I will report more info as I have it and will take pics....
Thad
Okay Thad,
About four years ago, give or take, I replaced the transmission pan (E4OD), and added a transmission heat sensor and gauge, and a transmission cooler. As I understand it this is what you want to do. I'd suggest that, as part of the process, you change the fluid in the transmission. It's easy enough to do. I'll send instructions if you want.
Since I have the photo location copied, I'll paste that in first. You can see the new, deeper, pan, and the heat sensor.
I bought the cooler from Dieselsite, a major advertiser here on this site. They couldn't have been more helpful. I'll deal with them again in a heartbeat. The cooler I bought is significantly more efficient and effective than the tube and fin model you're looking at. It's also more expensive, but not nearly as expensive as a new transmission.
TruCool Max Transmission Cooler
Almost forgot part numbers for the deeper pan. I'll simply cut and paste an old posting from Birken Vogt.
If you should want the deep oil pan for your E4OD with the drain plug and the reusable gasket, here is the part number for the kit, includes pan, gasket and bolts necessary to do the conversion:
F7TZ-7A194-DA
The pan itself, for the later E4ODs, is a
F81Z-7A194-BA
I had a hard time finding these numbers so I thought I would post it.
Birken
i hardly tow at all, but I was thinking this through today. I helped a buddy change the rad in his 1999 neon, and we had to take the A/C cooler off before we installed it. The A/C cooler is almost new and would easily fit in my truck as a trans cooler. It is about 13" tall X 25" long and just a single core. I can have it for nothing if I want it. Would this be a good idea on a daily driver?
I might run my stock aux cooler instead of the lower portion of the radiator. It just seems that the tranny portio of the radiator is absorbing heat from the upper portion of the radiator and not able to dissapate it!
Thad
