Does this work for 4x2?That the 99 4X4 ? Be sure you are getting the correct filter for a 4X4 they have a deeper pan, and take more oil 16 Qts. Are you draining the TC also ? If you do there is a certain procedure to refill the TC. Put in 6 Qts. run motor for one minute put in 4 Qts. run motor for one minute then check level with the motor running, add fluid as needed. The TC holds 2 Qts. fluid. To drain the TC, rotate until the plug is on the bottom.
Couldn't you just add one?Or if it has been rebuilt and the converter didnt come with a drain plug. I have seen several like this, mine included. I wish I had known it when I ordered the converter I would have had them put one in when they built it.
Would these not already have one? Or could you ask for one?Depends. A stocker you can. Aftermarket multi disk you cant.
