plywood
Recovered N/A
Yeah I did the tdc for each cylinder method and found the "what cylinder when" probably here. Still don't understand why the air method but maybe in certain cases there is a reason.
I’ll shine a little light on this issue since I delt with this before when I rebuilt my engine from hell a while back.
If you have a consistent chuffing sound, turn off engine and pull valve covers. Put pressure on each of the rockers towards the top (where the oil hole is) with your hand. If there are any rockers that move during this test, you have identified a faulty lifter that is unable to hold oil pressure. They should all be very stiff, with no up and down movement. Some side to side play is acceptable. You should not be able to compress lifter with your hand if they are all working properly.
This might also be a good time to remove the rockers and check to make sure you don’t have any bent pushrods.
If rockers, lifters, and pushrods check out, the problem is within your cylinder heads. At this time, you’ll need to pull the heads to properly diagnose and fix the problem.
Anyone know which brands of lifters have needle bearings?
@Hydro-idi
Did the Johnson Hylift lifters got directly from them end up at your door for less than $140?
Still haven't gotten any word on actual measured pushrods length, but 9.9890" overall length seems to be the only thing available that's not Enginetech/Redline. Rockauto has the 9.9890" Sealed Power pushrods. Planning on pulling the trigger on the parts soon as well as some Trick Flow valve springs (same as Comp 910's).
