Diesel JD
Okay, first off, I'm not new to IDIs but far from an expert. I feel very comfortable performing any normal fixes on the side of the road, up to and including injector or IP replacement. I suppose I'm asking for some wisdom from you IDI road warriors as to what common failure items on a long (1400 mile) trip might be and what items might need to be checked before I seriously commit to this. My thoughts are that I need to carry a spare set of belts, a few extra injectors and a few extra glow plugs as well as lots of water/coolant and oil and fuel hose of all applicable sizes. I was going to get a mechanic friend of mine to check the brakes, suspension and for any glaring safety issues. I also know there is a slow coolant leak...definitely not water pump or head gasket/big C. It is either the top weld on the radiator tank or the hose isn't tight enough. And speaking of hoses, the bottom hose is old. I don't know if it is bad but it has been in there a long time. My gut is to pull that radiator and check it real thoroughly and the bottom hose gets replaced. How would I check the radiator for leaks...let a shop do it? Or can I do it at home or at my buddy's shop? Also if I get into a really bad fix any OB folks that would be along the route (Mostly I75 between Gainesville and Milwaukee) and then heading NW toward the twin cities but actually heading for Hudson WI? Lastly, does anyone know where to get biodiesel in the Twin Cities or Milwaukee area? I feel like I'd have enough to get there, but probably not back without refilling. Looks like with a worst case of 12mpg I'd burn 116 gallons or a best case of 20mpg I'd burn 70. I should be able to secure a 55 gal aux. tank, 2 5 gal cans and my 19 gallon stock tank. I appreciate any advice.
