TWeatherford
The truck and I got a ride home on a wrecker the other night. On the way into work I noticed low fuel pressure (as in zero psi) and it running rough. Well it was cold and I didn't have a spare fuel filter with me so I went on to work. On the way home the same thing was happening and it just shut off on the interstate. I was hoping that it was just air in the lines from where it had pulled so hard against a clogged filter (I'm running a clear prefilter, it was full of nasty stuff, likely because I just started adding power service to the fuel) and finally sucked air in. Well I got the air out of all the lines up to the IP, cracked the injector lines at the injectors, and I can't get any fuel there. While cranking I've got 4 psi.
Just thought I'd throw it up here in case any one has any $500 saving ideas for me to try. The FSS is clicking. I don't really blame the truck, as running vegetable oil is ******* them (thermal shock when I switch to VO once I'm up to temp) and running it on 0 psi wasn't exactly helpful I'm sure. Looks like the price went up $55 since I bought the current IP (18k miles ago, ouch). I'll probably just go with Oregon Fuel Injection again, as I was happy with this pump, unless someone other company is now producing quality IPs for less money. I know a baby moose would be great for me, but I can't afford the wait time to send in and have this pump rebuilt. What is Mel's website anyway (so I can go look and drool)?
