bilbo
North Dakota
89' 7.3 IDI retired ambulance /full time service plumbing truck.
Sent from my moto e5 play using Tapatalk
I would hire you for plumbing work based solely on the name of your business, but the mileage charge would probably be pretty steep! Very clever and the Ambulance is icing on the cake!
KYBricksandBulls
Somewheresville KY
Im new here. Here is my 7.3IDI Bricknose pullin my 300I6 Bullnose from old house to new house.
Hope to meet some other Kentucky ford truck guys. Me and a bud are startin a Bricks and Bulls club at my new 30 acre place.
Kooper
Riesel
Does this count?
1966 Scout 800 with a 1988 7.3 N/A ZF5 Dana 300 and 1977 Scout II Dana 44’s
still not legally road worthy but I do get to drive it around at least.
Scotty4
Does this count?
Was the windshield target practice?
Rix_IV
Fresno, CA
Hey everyone, I've been working on my 1984 F250 with the 6.9 IDI that I inherited from my great-grandfather who had bought it new from the dealership back in the day. I stumbled across this forum and I love how active it is so I had to make an account. Anyways figured I'd show you guys my truck and I look forward to learning as much as I can about these beasts!
Chance jeffrey
Brush Co.
Here is my 91 f350 started its life as a 2wd in Canada according to the vin I got it December of last year for my first diesel project I lost the original pictures I took of it but the bed had been smashed in by an oilfield truck hitting it
Since owning it I took the bed off and mad a 1979 2 ton flatbed I found in the junk yard fit had to cut it down then I painted it I still have to put the lund visor back on
cason234
Lynden, WA
Here's a link to a YOUTUBE video I just made of my 1990 F250 with 7.3 IDI and ZF5
I bought the truck as a fixer upper, put a Dana 60 under it, and then spent time on the cosmetics and details..... it turned out really nice! I sold it to a young guy in town, and he let me take it Saturday to take pictures and shoot some video of it. Let me know if you have any questions!
Here's the details:
1990 Ford F250
7.3 IDI Diesel engine
ZF5 5 speed transmission
Borg Warner 1356 Transfer Case
Dana 60 Ball Joint front axle from a 1994 F350 (completely rebuilt) - with new bearings, seals, ball joints, u-joints, tie rods, steering linkage
4.10 gears
Redhead Steering Box
Spherical joint on clutch pedal mechanism under dash (replace factory plastic bushing)
Bed from a 1992 F250 (Bellingham, WA)
New Passenger Side Door from a 1993 F150
- new door keys on both sides at time of paint job
Replaced Sliding rear window with single window from wrecking yard
Tinted Windows
New Windshield
Paint is TOYOTA CAVALRY BLUE (painted @ TriVan Truck Body in Ferndale, WA)
Bed lined with Polyurea bedliner (sprayed @ TriVan Truck Body in Ferndale, WA)
Interior Door panels - base model OBS Ford pickup (auto wrecker in Chilliwack, BC)
Climate Control - base model OBS Ford (auto wrecker in Chilliwack, BC
Wood grain trim replaced with base model OBS Ford stuff
Needles for all gauges were completely faded - painted orange with nail polish
Steering Column - base model OBS Ford (auto wrecker in Chilliwack, BC)
NRG Woodgrain Steering Wheel with NRG Quick Release steering hub
Grizzly Fur headliner (wild grizzly @ Mt. Baker) - just kidding..... it was from Joanne Fabrics in Bellingham, WA
MINT OBS Ford Blue Velour bench seat
OEM shifter modified to shorten throws and place closer to driver's hand
Shift ball and transfer case ball from SICKSPEED (Amazon)
Ignition key replaced with toggle switch and push button start
Your choice of Horns for the situation: - FORD horn tells 'em who's boss, TOYOTA horn says "excuse me"
Pioneer Blue Tooth Receiver with Polk Audio 6.5" Door Speakers
Alternator from mid 90's Econoline with built in regulator (new from NAPA)
Auxiliary Blue Sea Systems Fuse panel
Gear Reduction Starter (cranks like a champ, whether hot or cold!)
New Radiator (Napa)
New Water Pump
Extended Life Red Coolant (7.3's require good coolant to prevent cavitation)
Synthetic fluids at all locations (except engine)
- synthetic transmission fluid
- synthetic fluid in transfer case
- synthetic gear oil in both differentials
- conventional 15W40 in engine crankcase
LED backup lights
DIY LED Tail Iights (GROTE LED Trailer led epoxied into aftermarket new taillight housings)
LED bed lights
LED Under Body lights (light up when door is opened, but can also be turned on independent of interior lights) -two diodes and a relay make it work like it came from the factory this way!
LED Light Bar at front of truck - actuated by high beams
16" x 8" aluminum wheels - painted with DUPLICOLOR GRAPHITE wheel paint
TOYO OPEN COUNTRY ATII tires sized 315/75R16
Greenie
1993 F-250 purchased new for $25,000. It has 277,000 miles. It has towed a 3 ton travel trailer to and from Sinaloa Mexico 8 times, yarded out logs when we cleared this lot 22 years ago, and plowed snow. The body is a Reading I used for an oil burner business I had for a few years.
Maaco replaced the radiator support, front fenders, rear wheel arches and cab corners back in 2005 before painting it. The paint has held up well. The transmission was rebuilt in 2004, injectors and injector pump replaced (although it didn't really need it) 2,000 miles ago.
I've replaced the starter, water pump, mechanical life pump, alternator, power steering pump, wheels, brake pads and shoes, steering shaft, and radiator once... oh, and plenty of u joints on the rear shaft.
It will tow the travel trailer at 85 mph (wind and hills permitting) and I might try towing cross country with it again.
Thanks for looking!
Tod Rockstead
El Cajon CA 92021
This is my 1986 F250 XLT 6.9 IDI AUTOMATIC 4X4 wth BANKS TURBO SIDEWINDER with standard 2 tanks + 1 200 gal tank in the Bed.
catbird7
PA
I have one of those turbos on a parts engine in my shop.
Mishka
Fort Knox, KY
More changes coming but so far leer topper, Yokohama geolander g003's, olive drab paint (still gotta wet sand it) from restoration shop, warn winch, affordable off road bumper.
Coming soon install of new can bushings, new leaf springs and new custom made heated and massaging seats
lmbma2003
Here is my rig. 1990 F350 Dually with 7.3 IDI and E4OD tranny with a 4.10 rear end. I have a long ways to get with my plans for it. Rebuilding the E4OD installing a heavy duty shift kit, eliminating the bed setting up a Hot Shot hauling design for my future 5th Wheel, installing new AC parts, install a electric radiator fan, plus many engine upgrades. Wish me luck!
JU57US
