Testing a front fuel sending unit that reads empty
Clb
Another old truck
nannyfornia
P
 o
r
n
time...
Greenlee punch for bx fitting in background, doing a 3/4" harpoon vent mod
Harpoon mod setup
And yes the yellow ptfe tape is petroleum rated. The white is NOT.
Modify the rollover valve by cutting the top off @ the nipple port.
TAP ALL THE WAY DOWN, for the front tank.
Sink it an inch deeper for the rear tank as its right under the bed floor.
Check fit as you go so it's still snug.
Clb
Another old truck
nannyfornia
More
If you remove the dr side bed bolts, then loosen the passenger side all the way you can floor jack the bed up and shim it in place so yer not relying on the hydraulic jack to save yer butt.
Clb
Another old truck
nannyfornia
Sunk float
Showerheads still supple, shelled the poppit valve gizmo.
Following the advice of the other threads about this above, I ordered the floats.
Cuz everything was as instructed above.
Fwiw
I installed a set of fuel filters tween the tanks and fsv as a failsafe for the fsv.
This setup is not great for the rear tank as its a p i t a to access this way.
I'm gunna drop the rear instead of fighting all the sheilding on the front one.
Hope this saves some future idi'r some grief, having all the links in 1 thread.
May as well do a 3" body lift so you can clear 33's. Your half way there.
Let's make that unicorn a stallion!
  • Like
Reactions: Clb
Clb
Another old truck
nannyfornia
Ummm
Do Dis Count?
35's doubled and locked
The ferd is a cowboy caddilac/tow pig...
Ummm
Do Dis Count?
It's acceptable. Those little trucks sure got a "cult following", I'd like a AMC CJ one day, but probably not today.
Clb
Another old truck
nannyfornia
Not an AMC, Pre kaiser , first year civilian
willy..
Better?
DaveBen
Ukiah, Ca
1946 CJ-2A. I got one when I was in college and towed it back to Nor Cal. I spent over $50,000 "rebuilding" it several times. Lotsa fun and money. I learned a lot about 4 wheeling and trucks.
  • Like
Reactions: Clb
I had one for a time too. I had it for about 3 years and had done nothing to it at all so I decided to get rid of it.
dieselmainiac
