OK, I've read this and searched all over for installing a tach onto my truck. It had a standard gauge package without a trip meter, and no tach. I went to my local pick and pull, and found a real nice gauge cluster with a trip meter and a tach. I pulled it out of the truck, as well as the sensor. brought it home and tried to hook it up. all of the other gauges work just like the original, with the same readings, except the tach sits on 0. Am I missing something from the donor truck? the truck in the yard was an auto, I swapped out the gear indicator on the gauges for the one in my truck (t-19). and i cleaned the sensor, installed it to the correct location, and plugged it into my factory harness. I was always wondering what that big plug was for. the sensor does have an area of exposed wire, so is there anything else i can check or missing before i buy the $80.00 sensor?
