IDI Til I Die
Im in the middle of this swap and I have some questions. Do you have to remove the y pipe and starter to install the zf? Also I cut the throwout bearing fork open a bit and it fits the zf5 throwout but Ive heard the fork needs some weld bead built up on it to move the throwout bearing a little further is this true?
